Home > In Car Electronics > Making up Anderson connectors
Bluest
What type of tools (crimpers etc.) do I need to make up my own leads with 50amp Anderson connectors on? Trying to work out if it is worth buying the gear to do it myself.
Alternatively, are there people who could make leads up for me? 2007 110 TDCi Station Wagon XS
Post #688563 24th Feb 2018 8:25am
BigRuss
When I did mine I looked at these
https://www.torberry.co.uk/product/tt-82-h...20mm-cable
But in the end went for this
https://www.torberry.co.uk/product/tt-83-h...mping-tool
It worked really well on the Anderson connectors and everything else. The only thing it didn’t work really well on was when I made up some jump leads, the croc clip end didn’t work very well on one of them. Russell
2011MY 110 XS USW Black
Post #688565 24th Feb 2018 8:39am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I bought one of these for winch wiring, anderson connectors etc.
For the money I wasn't expecting it to last long but had it a few years and it's done well Very Happy
http://www.ebay.co.uk/itm/416371-Hydraulic...SwcB5ZMXWl 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #688605 24th Feb 2018 1:59pm
Sockpuppet
Re: Making up Anderson connectors
Any HGV garage will have the ability to make them esp if they deal with refer trailers. If you buy all the bits and drop in with some biscuits for the break room they should be able to crimp it for you.
Post #688612 24th Feb 2018 3:22pm
bankz5152
Tad unorthodox but I filled mine with solder, then heated with a blowtorch until molten, forced the wire in then left to set. 4 years later and many uses still going strong.
Post #688617 24th Feb 2018 3:57pm
gilarion
I likewise got someone else to do the crimping. In my case, it was a Lucas Auto Electric garage. Gave them all the bits and they charged me a fiver, and that was crimping two plugs with fly leads and two heavy duty battery jump connectors as well. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #688618 24th Feb 2018 4:02pm
Careful use of a vice also works.
I tend to heat them up as well, not only is the metal softer when hot but when it cools it'll constrict the crimp even further going back from its heat expansion. Chillin In The Backwoods🇬🇧🇺🇸
Post #688619 24th Feb 2018 4:10pm
Bluest
Thanks for the info. I'm minded to give the cheap hydraulic crimper above a go. Satisfy my never ending thirst for new tools. 2007 110 TDCi Station Wagon XS
Post #688623 24th Feb 2018 4:38pm
Mc071963
United Kingdom 2006 Defender 90 Td5 HT Rutland Red
I made mine up with a mate of mines help who runs an electrical contracting company.
he has several sets of manual, hydraulic and electrical crimp tools that do all sorts of sizes including the one you will need.
You could always try a local contractor out your way .... it actually only takes 5 mins to do the job ..... TD5 90 in Hertfordshire
Post #688628 24th Feb 2018 5:04pm
Rashers
You should be able to hire crimpers. When I was in the electrical contracting business, we regularly done this as they were calibrated and you knew it was going to do the job properly.
I've never tip-toed into the auto-electric business.
The solder idea is spot on and how it used to be done before my time. As for the vice, not so sure. It will close the crimp but how good the electrical connection would be, that's open to discussion. Saying that, I have been told the crimpers of choice for the electricians who went before me was a cold chisel and big hammer. I wouldn't recommend that, but it works.
I wouldn't bother buying crimpers. We only ever used them every now and again and a hobbyist car mechanic, possibly never again. But who an I to stop you increasing your tool collection. I've wasted more money on less.
Post #688631 24th Feb 2018 5:26pm
It’s possible to buy presses for it, to use with a vice as well but quite fiddly I’d have thought.
I’ve never understood the extortionate prices of crimping tools, I could understand it if a great deal of engineering was involved but in most cases it’s cheap jack stuff with a big price tag. Often more money than the project costs, and likely to use less than a handful of times in a lifetime. Chillin In The Backwoods🇬🇧🇺🇸
Post #688633 24th Feb 2018 5:42pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
When I did my winch cables etc I bought one of these, as I don’t need it for many jobs. Works great when ever I needed it and cheap enough.
https://www.ebay.co.uk/itm/6-50mm-Crimping...0005.m1851
Post #688637 24th Feb 2018 6:12pm
Screbble
When I used to work in electrical contracting, we used to use the expensive crimping tools as they would be used heavily and frequently, but looking at the cheaper copies on eBay etc (as above) then I'm sure they'd be more than adequate for the home mechanic DIYer.
I have a few crimping tools that you can borrow or I could crimp them for you if you are venturing anywhere in West Lancashire in the near future.
I've just completed my SB 175 Anderson installation using 35mm2 cable.
Post #688654 24th Feb 2018 7:54pm
Mdm
the cheap hammer ones don't work well.
i use one of these for many years now.
https://www.ebay.co.uk/itm/Ref-TN70-Heavy-...xyY9VRUvyh
solder works well as does the vice crimp method
Post #688658 24th Feb 2018 8:23pm
Screbble
That last one looks like the same pattern we used to use for the steel wire armoured cable on site.
Good bit of kit - simple and effective. Not much to go wrong. Thumbs Up
I have one of those 'hammer' crimpers in the garage somewhere - they are ok if used with a vice, but that also renders them less useful if your wiring is in situ in the car! Rolling with laughter
Post #688660 24th Feb 2018 8:33pm
