Home > Maintenance & Modifications > Fibreglass hardtop options - winterproofing td5 soft top?
c_eilersen
Denmark 2006 Defender 90 Td5 ST Tonga Green
Hi guys,
I am trying to find a way to make my 2006 TD5 soft top a bit more pleasant during the cold winter months in Denmark.
I love the soft top during the summer months but in the 6 months during fall/winter the soft top gives me nothing but loud flapping noises and not much pleasure at all Smile
I was considering buying a standard hardtop and rear door and just make the switch every spring/autumn.
The switch is complicated a bit because I have a heavy duty hoop set from exmoortrim fitted+ I would like to avoid buying and changing the rear door aswell.
The optimal solution would be something like the NAS style fibreglass top - which fits directly on my car and fits with my existing tailgate.
They do seem to be hard to come by - anyone know a place within the EU that have these - or a similar alternative?
best,
Christian
Post #688602 24th Feb 2018 1:44pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
They aren't particularly cheap / easy to come by but have you looked at a series style catflap? That combined with a roof / side panels would work without the need to remove the tailgate and swap to a full door, you'll still need to remove the hoodsticks though.
Worth trying a fume curtain with the soft top, it's made mine much warmer and quieter. Swapping the rope for strong elastic cord and pipe insulation on the hoodsticks also helps. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #688607 24th Feb 2018 2:32pm
zsd-puma
Do you actually use the rear load area for passengers? and do you still have a bulkhead?
If you don't really need the rear area for passengers and you have a bulkhead, then a truck cab would be a fairly easy fit, and easy to store as well as pretty cheap to buy. You could just leave the rear hood sticks in situ. or throw a canvas tilt over them.
Post #688638 24th Feb 2018 6:13pm
