Home > Wheels & Tyres > How to set torque setting - steel wheel nuts
Page 2 of 2 <12
miker
LandRoverAnorak wrote:
Hands up who's fitted a wheel without using a torque wrench and not died as a result?
I use one when at home, when not at home my breaker bar is a similar length to my torque wrench, so I tighten it up to a similar level of grunt!
Post #687116 17th Feb 2018 12:12am
agentmulder
Kuwait
I've found that when I torque up any wheels (not just the wolfs) that after they're all done and i go for a 200m drive up and down the rd, over a couple of curbs then park it up again and repeat, often I'll have a little bit more to tweak them before the click...
But to answer one of your questions, I don't think there is a reliable enough gauge of 'how much further to turn to get the extra required stud tension/nut compression/friction' other than your accumulated personal experience having had a wheel come off or not Thumbs Up Solved the bowel problem, working on the consonants...
Post #687123 17th Feb 2018 5:00am
Mo Murphy
Your Land Rover wheel wrench is a particular length for a reason ...
50 Shades of Pennine Grey
Post #687156 17th Feb 2018 10:11am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
You should always re-torque after driving 10 or so miles after the fitting. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #687161 17th Feb 2018 10:51am
discomog
I religiously tighten wheel nuts with a torque wrench, however during my apprenticeship at a Land Rover dealer in the 1960's i never once saw a torque wrench used to tighten up wheel nuts we used the good old fashioned spider wrench. I know it's more critical with alloys and that over tightening is more of an issue than not tightening enough.
[/i] Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #687163 17th Feb 2018 10:53am
miker
Sadly these days a lot of main dealers use the method of air gun till snug, then a few more ugga duggas and that'll be reet
Post #687164 17th Feb 2018 10:55am
Page 2 of 2 <12
