Home > Td5 > Replaced entire braking system - 3 amigos remain! |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 |
Awesome, thanks. Will get this done at the weekend. It looks like on the wiring diagram TC only has a wire fitted on ABS models. So I'm free to just cut this wire and cover the end up? And ABS models have pin 14 connected to brake level switch already, so I don't have anything to do there? All I'm doing is pin 13 to 9 and pin 10 to 6? And then cut the TC wire at pin16 to turn off that lamp? Click image to enlarge |
14th Feb 2018 11:34am |
Pins / connectors arrived from eBay yesterday. Jumped both ABS Light and Brake light, disconnected the ABS ECU and now all 3 lights are off.
Thanks everyone. Brake warning light doesn't come on in the start up sequence, I'm not worried, but is it supposed to? |
23rd Feb 2018 12:46pm |
