Home > Puma (Tdci) > its all gone pete tong |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
update
its still in the dealer they are removing most of the wiring loom now seem to have a fault with the wiring which is blowing fueses daniel |
4th Feb 2009 10:31am |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Daniel,
Their comment about water behind the dash could well be correct. I had the common problem of "water in the foolwells", the drivers side mostly. However, the water only appeared after driving off after a heavy shower of rain. All the time the vehicle was stationary, life was rosy. The water dripped down from the trim under the steering column, presumably just sitting there doing what water does untill driving off. Miraculously, the dealer appears to have fixed it, but seems reluctant to say where the water was getting in. I'd not only be worried about water in the electrics, but also unseem corrosion! Bosun. |
4th Feb 2009 10:53am |
