![]() | Home > Puma (Tdci) > Handbrake switch |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Are you sure its the handbrake switch? Have you checked your brake fluid?
![]() Sorry if I'm teaching you to suck eggs. ![]() |
FearlessLeader Member Since: 12 Feb 2018 Location: Northampton Posts: 3 ![]() ![]() ![]() |
Thank you I have had a look and brake fluid seems to be ok, and if I tap the handbrake switch it tends to go out, it does come back, and its flicking on and off all the time now,
Driving me nuts lol haha |
Any chance of getting a multimeter on it? If not part number appears to be EEP191L for the switch.
Ah thats great thank you, ill try multi meter but thanks for part number ill have a google
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
Who told you, that the switch is not available for RHD as a single replacement part?
Microcat told me, that there is a difference in the lever, but the switch seems to be the same for RHD and LHD. /Max |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3791 ![]() ![]() ![]() |
Had a problem with the handbrake light myself. I think the light switch is at the base of the handbrake lever,...I used to give it a bit of a squeeze there, and it would go out,..sticking switch?!!
Pickles. |
