Home > For Sale & Wanted > [Wanted] WANTED URGENTLY VOR
noworries4x4
Does anyone in the Exeter / Devon area have a top swivel pin bearing assy TAR100040 sitting in their garage that I could grab tomorrow VOR
I went to Matfords this morning and collected the bottom bearing and pin but stripped it out between the rugby this afternoon and its the top that has collapsed not the bottom. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #685580 10th Feb 2018 5:32pm
grafty99
If you're desperate then you can have one off the front of my spare Range Rover rolling chassis to get you by if that's any help? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #685607 10th Feb 2018 6:21pm
noworries4x4
I have emailed a couple of parts suppliers on ebay to see if I can collect direct from them in morning, one has a unit in Collumpton so that would be the easiest option. I need to be on the road Monday morning job in London to go to for 07.00. If everything is under control you are not going fast enough.
No Worries 4X4
Post #685613 10th Feb 2018 6:43pm
grafty99
If not it may be easier for you to swap the whole axle end if you end up tight for time? Saves setting up swivel preload etc. Let me know if you get stuck Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #685614 10th Feb 2018 6:45pm
