Home > Puma (Tdci) > Injector life 2.5tdci |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
So the engine replacement saga continues. Seems that at 110k miles the injectors need reconditioning or replacing.
What is the service life of injectors? Should I replace or the new set after 100k miles (along with a timing chain set)? Thanks |
9th Feb 2018 9:01pm |
2.4 tdci fat thumbs and small phone + apparently age
9th Feb 2018 9:07pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Mines on 130,000 and no issues, I know there are others on here with higher Mileage,
There are also Plenty of high mileage Transits running around 200,000 miles + I tend not to touch injectors, they will soon let you know when something is wrong, they’re not cheap to have the full set overhauled, last ones we had tested and fully refurbed were just under £650. Wise move on the chain though, Turners do the kit for sensible money, cheaper than most factors can. https://www.turnerengineering.co.uk/Mobile...02x3005731 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
9th Feb 2018 9:21pm |
