Home > Puma (Tdci) > They can wade rivers and climb mountains, but not a car wash |
Setok Member Since: 16 Jan 2009 Location: Helsinki Posts: 419 |
I love that picture of the Series Landy. New technology confronts old. Brilliant.
23rd Apr 2011 8:50pm |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
Cheers Setok
23rd Apr 2011 8:51pm |
Love you to post a photo of them
25th Apr 2011 9:05am |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
This is the thread you want Kez
http://www.defender2.net/forum/topic5101.html Peter 2008 SWB Truck Cab 1952 80" Soft top |
25th Apr 2011 9:27am |
Fantastic - beautiful photos of your dogs
25th Apr 2011 9:32am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Water entering through the side intake should easily drain away at the bottom of the airbox anyway, its not like water is being forced up the drain hole like in the event of a fast drive into deep water which could lead to water breaching the air filter and hence getting a MAF fault.
cheapest way I know of a decent diagnostic is an android phone, a bluetooth OBDII key and a app called "torque". it reads all puma faults and can clear them. |
29th Apr 2011 10:21pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Kez now has a Scanguage - so next time it happens, if it does, he should be able to see the problem code??
30th Apr 2011 7:00am |
Have since been through same wash three times, no further warning lights or problems of any sort - it must know I bought the scangague
1st May 2011 2:33pm |
Hi Kez, is your special wash open in the evenings? On an awayday to Exeter tomorrow so thought I could call in and get all the dead flies etc: washed off on my way home.
4th May 2011 5:11pm |
Hi WG, its not my wash, wish it was, owned by a company who supply the system to UK dealers - more info here:
http://www.touchfreecarwash.co.uk/ I am pretty sure its open until 8 if not later, but if your passing just have a look anyhow! Regards Kez |
4th May 2011 5:33pm |
Guess what, its closed until tomorrow (Friday) - also found out its open from 6am till 10pm if that helps
5th May 2011 4:34pm |
As you said, closed for maintenance. Never mind, next time
5th May 2011 8:42pm |
Send me a DM next time you know your passing WG and I see if I can sort you out a freebee !
5th May 2011 8:49pm |
sookoon Member Since: 02 Nov 2014 Location: PUERTO VARAS Posts: 40 |
Sorry for the tardy reply, but for what it's worth, when I purchased new vents for the wings, the instructions said, do not pressure wash too close to the vent... |
7th Dec 2014 11:33pm |
