Home > Td5 > washer pump |
You might have a problem with the none return valve at the n/s in front of the bulkhead or a kinked pipe as the standard pump works quite well when everything is set up. Ray
4th Feb 2018 5:40pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
Cheers for that. I'm going to be stripping part of the dash down in a few months for some other jobs, so can have a gander whilst I'm in there, but I think the pump is underpowered anyway.
I might just scour the scrapyard and see what I can come up with (the washer bottle is leaking anyway where one of the pumps clips in, so its got to come out to be addressed anyway) |
4th Feb 2018 6:16pm |
Reading Blackwolfs' contributions to the headlight washer thread, I think he's found a way of mounting a bigger pump from a D2 using an adapter made by Optimill. No idea of cost but may be worth a look. Darren
4th Feb 2018 6:19pm |
I'll have a look... cheers!
4th Feb 2018 6:27pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17391 |
Here you go. On the left a Disco 2 headlight washer pump for the screen washers, on the right a Rover 45 headlight washer pump for the headlamp jets. I haven't fitted it yet so can't tell you how much better it is, but the pumps are much more powerful than the pathetic standard pump. The mounting hardware is from Optimill.
4th Feb 2018 7:06pm |
Perfik! thanks
4th Feb 2018 8:24pm |
