Home > Tdi > 1995 300tdi vented discs or solid?
horus1970
England 1995 Defender 110 300 Tdi HT Portofino Red
anyone know what calipers i should get for a 1995 110 hardtop? ones for vented discs or solid? the reason i ask is my vehicle isnt here right now and i need to order new front calipers and discs,, if mine are solid discs is it just a case of changing calipers and discs to upgrade to vented?
Post #683421 1st Feb 2018 2:30pm
donmacn
My car is a 1994 110 SW 300Tdi. It's vented at the front, solid at the rear. I imagine this would be the same on a hardtop of the same era - but I'm afraid I couldn't say for sure. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #683437 1st Feb 2018 3:35pm
Retroanaconda
Your 110 should have vented, though in 23 years previous owners may have fiddled with it.
But if you’re buying both calipers and discs then just get vented anyway as those are the only parts that differ.
Post #683481 1st Feb 2018 7:07pm
horus1970
Thanks for that lads, just wanted to make sure axle mountings weren’t different
Post #683637 2nd Feb 2018 2:51pm
Procta
are you getting braided hoses too? that would be another upgrade to do if you are sorting out the brakes Thumbs Up
One thing is why the hell do defenders have the solid discs at the front? Id have thought due to the weight and what they used for, they would have vented at the front. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #683755 3rd Feb 2018 1:46am
sako243
110s have since the 300Tdi always had vented as far as I know. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #683764 3rd Feb 2018 7:36am
You can put vented on with 110 calipers. My puma, being a truck cab has solid discs, so I'm converting it to vented, I did it with the v8 too.
Post #683765 3rd Feb 2018 7:56am
horus1970
I’ve just bought a full set of vented front discs and new calipers and new rear solids with new calipers, will buy some braided hoses too, like you say I might as well put the braided ones on while there off and getting changed,
Post #683981 4th Feb 2018 12:27am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
I've fitted vented discs to the rear also using brackets from red.winches.com I'm building it into a camper which will be quite heavy + I'll reduce the service parts I need to carry.
Post #689397 27th Feb 2018 8:02pm
horus1970
im making mine into a camper too, hopefully ready for summer,
Post #689458 27th Feb 2018 10:30pm
