Home > Tdi > Land Rover Wolf Donaldson Air Filter Mounting Bracket
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
Hi all
I have a LR Wolf/TUL/TUM Donaldson air filter / air cleaner box i'd like to fit to my Defender 300 tdi engine.
can anyone tell me the part number of the mounting bracket needed for the 2 Donaldson bands that came with my air filter box? thanks 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #683268 31st Jan 2018 8:44pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Should help Thumbs Up
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #683301 31st Jan 2018 10:05pm
Mash
D3 Hse - Fiona
Capri 2l S - Anna
Post #683302 31st Jan 2018 10:06pm
foxhound
[quote="Mash"]Should help Thumbs Up
thanks very much Mash. that's the right air cleaner box. have you got a page that shows the mounting bracket and part no for the mounting band (P777731, number 8 in the diagram) to fit on? The band is pretty large and needs to screw to something. thanks again 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #683329 1st Feb 2018 5:25am
Mash
Sorry for the delay Foxhound,
This is the only mounting in the AESPs, been a long time since I have worked on a deserterised Wolf to remember how it mounts Embarassed
D3 Hse - Fiona
Capri 2l S - Anna
Post #683740 2nd Feb 2018 11:22pm
foxhound
thanks for this. i reckon the AESP is missing something but i can bodge it.
in UK conditions, especially in the winter or on road, i can't see that the safety element inner filter needs to be used, am I right? not exactly extreme dust at present! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #684309 5th Feb 2018 4:03pm
Mash
It should be ok, after replacing a fair few filters like this in uk/ Germany the inner filter is often perfect with only the outer showing any dirt. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #684424 5th Feb 2018 10:10pm
Mash
Il try and do some digging on the mounting if your not in a huge rush Thumbs Up
Seem to remember they are mounted at an angle, will trawl through some old photos and ask around to confirm. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #684426 5th Feb 2018 10:17pm
Mash
My thoughts were correct the filter housing is mounted at an angle;
D3 Hse - Fiona
Capri 2l S - Anna
Post #684688 6th Feb 2018 11:01pm
foxhound
thanks for this Mash
i got mine in this way
i used the existing bracket and counter sunk the centre hole and ground the nut so it was flush and used 2 bands as only one end of a band would fit on the bracket to be bolted.
Post #694293 18th Mar 2018 11:09am
Mdm
heres one on a 110 snatch 2a
Post #694471 18th Mar 2018 7:07pm
