Home > Puma (Tdci) > TRACKING... |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
The garage have set your tracking wrongly. The wheel should be fixed in the straight ahead position, then the necessary adjustments made. 2007 110 TDCi Station Wagon XS
31st Jan 2018 7:37pm |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 |
I know, but i dont have the time to mess about taking it back, so need to know if i can move the steering wheel round one tooth
31st Jan 2018 8:15pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 712 |
Start by checking that the draglink length is correct and the drop arm is in the centre of it's movement range when the wheels are straight ahead, once that's correct then adjust the steering wheel to suit. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
31st Jan 2018 8:24pm |
Moving the steering wheel one spline on 2.4 Puma’s it’s fine I think but don’t now if causes any problems on later models. Might be a problem if the later ones with esp have a steer8ng angle sensor.
One spline is actually quite a big change and you might find it goes too far the other way. 2007 110 TDCi Station Wagon XS |
31st Jan 2018 9:44pm |
