Home > In Car Electronics > Looking for ideas |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
I think Jomara on here has similar, but not in use yet I don't think. No Guts, No Glory.
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
27th Jan 2018 9:43pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Hi Chris
I have ordered a Kenwood DMX7017DABS double din unit, loom, reversing camera and a Defender Upgrades dash with moving vents, just waiting for the kit to arrive and my car to come back from the dealers yet again to get it all installed. Did a lot of reading and was nearly buying Pioneer but they have an issue with DAB tuner errors stemming from a non replaceable internal fuse popping. The Kenwood scored 5 stars on the Auto Express tests and the one I tried in a VW was remarkably simple to use and they donโt seem to any major problems at the moment. Hopefully it will be up and running over next couple of weeks. Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
27th Jan 2018 10:16pm |
Keep us posted. No Guts, No Glory.
27th Jan 2018 10:18pm |
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 371 |
What do you look for when by an amp. I want to put more speakers in
28th Jan 2018 8:39pm |
Match RMS wattage of Amp output to speaker RMS wattage. Or as close as you can.
So if your Amp produces 50wrms per chanel at 4 Ohm, that is one channel. You would need a single 4ohm 50wrms speaker. (Or near). That is an example, it also depends if wired in series or parallel as to your final impedance in Ohms and wattage. Depends how many speakers you want but you'll likely require a 4channel Amp. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Jan 2018 8:48pm |
Basically at the moment I've got 2 10cm Hertz and Rainbow flat sub. I've also 2 16cm Hertz speackers that I'm going to put in the seat boxes. I'm starting at the front working back over.
I want to put the sub under the cubby box. Just want the best sound I can get out of it |
29th Jan 2018 1:49am |
