![]() | Home > Puma (Tdci) > Second row seats aftermarket replacement. |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 ![]() ![]() |
Perhaps I could modify the existing mechanism and file in a extra slot that would allow a recline and manually set the seat when a recline is needed with a bolt ( or split pin?) through the metal to retain it??
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Let me know how you get on Diffbeer. It's true the nippers' heads do roll around all over the place when they're asleep.
Even if there was just one notch back it would sort the problem. ![]() |
Take care when messing with the seat mechanism as the back rest could possably fold fowards or backwards in an accident (god forbid) 2.4 90 XS
Yes i'd be very weary of tinkering with the standard seats too, but if there was an alternative, it would be good.
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I wouldn't worry too much about them folding forward - there is very little structural support in the seats anyway - it all comes through the seat belt. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5069 ![]() ![]() ![]() |
I disagree. Folding forward or backwards - or any failure, the seatbelt only holds you in the seat. Any incident, any injury (heaven forbid death) and you will be so far in prison so quickly its not worth it. Mike |
Sorry - to be clear: I don't advocate messing with the seat mechanism. The Puma seats are much better than they've ever been before - and much safer too. The last thing you want is the seat collapsing on you - mostly because you'll slip out out the seat belt.
In a head-on collision, your seat, however, won't provide much support. If the seat remains fixed, you'll depart from it and be 'gathered' by the seat belt as it tensions. You'll then recoil into the seat cushion. If the seat is free to fold forwards the it'll travel forwards into the belt as well and you'll have the additional pressure of the seat decelerating on your back (not good, of course). The seats on my old Renault 4 used to just lift out. Not ideal, I admit. |
Had a good look at the mechanism and the seat -- the upper part of the seat belt attachment is located almost in a straight line to the top of the back seat.
Its fair to say that this seat is really only safe in a completely upright position or for a large adult in the normal position. As for a child n a booster seat in the normal position - I think it is unsafe , as the seatbelt does not exert enough tension . The seatbelt setup barely allows enough tension to really fixate a child seat. It would be unsafe in a reclined position unless the seat belts upper attachment is moved backwards to a internal hoop on a roll cage perhaps. ![]() |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Same problem here...
My two little girls have a big problem when they fall asleep. If you find a good (safe) solution will be great! I remember my Ford Windstar were the 2nd and 3rd row seats were reclinable avoiding this problem. ![]() ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
1ten.neuss Member Since: 07 Nov 2008 Location: Neuss Posts: 27 ![]() ![]() ![]() |
Hi,
I have recognized that by turning the head-cushion 180°, so that they are facing backward, the child seat of my 6 year old daughter has more space on the top to follow the curves of the seat. It's not MUCH better but a LITTLE. Regards from Germany, Bernd |
