Home > Tdi > Tdi boost compensator leaking
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
My Tdi's fuel pump has decided to leak from the breather on the fuel compensator.From what I have found it looks like it can only come from around the boost pin or fuel pin.Any idea's on the best way to fix it. thanks.
Post #680658 22nd Jan 2018 1:23am
Retroanaconda
It'll be the o-ring that seals the fuel metering pin into the pump housing. Mine had the same.
The pump will need stripping to sort it.
Post #680757 22nd Jan 2018 4:31pm
