![]() | Home > In Car Electronics > Sub / amp wiring route |
If you don't have heated seats there's a rubber bung in the top of the battery box you could go through. So down from the amp and under the seat next to the seat runner then into the battery box. Ray
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
Ah I have heated seats
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
There is more than 1. You could always drill a new hole a fit a rubber grommet
I'll take a look and report back cheers
You could just make a bigger hole in the rubber grommet. Ray
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 ![]() ![]() |
I made a bigger hole and shoved the wire through, then along the funny lip where the bulkhead was. I put the wire into some coiled plastic protective covering, used a seat runner bolt for my earth. The input cables from the head unit under the carpet and along that lip thing. All works well, v loud (1200W Juice sub box), nice!
