![]() | Home > Maintenance & Modifications > Best LED light bar and rear lights. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Lazer.
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
Lazer Lamps Seconded
Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
They look like great quality lights, but ideally i am after around a 52" light bar to go above the windscreen on gutter mounts
After the best?
Lazer Lamp or Vision X Now to be road legal optional driving lights have to carry an APPROVAL mark. Note APPROVAL mark NOT Emark Chances of cheap LED bars being approved for road use is minimal. Brendan |
The chance of finding one that will be road legal is next to nothing. We have a Vision X mounted on our green 110, not road legal! A good 52" light bar is TOO bright for most uses. Too much reflection from road signs, tree trunks etc. OK if you are going into big wide open deserts. Switch the lightbar off and onto good bright main beam headlamps and you will be driving 'blind' for a few seconds as your eyes adapt to large change of light level. I would advise smaller ones which can be switched on indidually or in pairs so you can alter the light level. Brendan |
I will be having a separate switch in the cab, as the light will mainly be used for work purposes, to light up my work space... so looking for a full 52" that wont be connected in any way to my driving lights for road use. Thanks for the replies
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1238 ![]() ![]() ![]() |
Rigid Industries? Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
defender_uk Member Since: 12 Aug 2011 Location: SW Scotland Posts: 197 ![]() ![]() |
is there a way to fit them, especially rear working lights. without having to drill the body? I really don't want to go down the roof rack route if i can 'elp it. 2020 First Ed 110.
replaced by 2021 250 110 Commercial Defender_uk |
OK then a triple r 28 is near as dammit 52 inches wide. light that one up and you'll bring down UFO's with the beam https://www.lazerlamps.com/home/lights/triple-r/triple-r-28-std Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Gutter clamp? Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Rigid industries now have an E approved line, and I must say the performance and quality is awesome
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
![]() Click image to enlarge Lazer rs8 in a bar, triple R on the rack ![]() I also have the Lazer utility 80 rear which i have in a box still to fit... ![]() |
Lovely looking truck there.
I can confirm the triple r is a bit overkill for the majority of Driving, but it is lovely when your out in the sticks... like daylight Driving
The rs8 is road legal I believe and have on my high beam stalk... it’s probably more than enough but I just like the look of the big bar hence having it... Been on maybe 9 months 0 water ingress |
