![]() | Home > Off Topic > Very heavily camouflaged mule |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
I was heading up to Coventry tonight and pulled up behind a very heavily camouflaged Land Rover Range Rover mule Jcn15 M40 then followed it up the A46. Not the normal little white and black box print, this time green and black grass type pattern, in the dark very hard to make out a shape. I have read things about a new 2 door coupe Range Rover and this would fit that bill exactly, bigger than an Evoke smaller than a fullfat very BMW X6 shape but lower. Struggled to keep up with it in the Defender. I pulled off at the Stoneleigh Park exit. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 722 ![]() ![]() ![]() |
Jaguar I-Pace. The all electric Jag. They are the only ones with green camo. A quick Google shows it.
They are very quick ![]() My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
No wonder I had to pedal hard to keep up, and yes now you mention electric I don't remember any exhausts. If everything is under control you are not going fast enough.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
They had two I-Pace in the outward journey of this years Lord Mayor Show. Only had one on the return journey
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
![]() Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
It wasn't that, much bigger but the cammo is correct, might be electric Range Rover then ??? If everything is under control you are not going fast enough.
