Home > Td5 > What started as...... |
Get it remapped now and you'll never look back Ray
19th Jan 2018 7:25pm |
Knocker458 Member Since: 21 Feb 2014 Location: South West Posts: 45 |
My mate said the same, I need less month and more pay first! Definitely on the cards though.
19th Jan 2018 7:28pm |
Ran the 110 for about 200 miles, then.....bang, more smoke, covered both lanes of the A38, pulled over and turned off ignition, engine ran away, put into second gear foot of the clutch and stalled it, dead! Recovered home then a car to garage who did the work, lots of expletives. So after a further investigation it turns out the head they fitted, after skimming and pressure testing, had a crack too and failed, so did the turbo, unsurprisingly after suffering 2 head failures.
The garage did the honourable thing in purchasing a new recast head and acquired a second hand turbo and finally all rebuilt and working well.......not quite. I picked it up last Friday and it drove really well. After such a long time away I was really pleased to have it back and looked forward to getting out in the snow. Saturday morning I went out to...a lot of snow and a significant oil leak After taking off the covers it looks like it was coming from behind the viscous fan, hitting it and going everywhere. Monday morning back to the garage where we nearly had a moment ‘not sure we touched that area’ followed by ‘if the exhaust had fallen off I’d have seen that as bad luck’ almost an engine rebuild and it’s leaking oil, a lot, from the engine, fix it!! I pick it up Friday, more updates to follow. |
20th Mar 2018 8:28pm |
nightmare! Hope all goes well this time, keep us posted Ray
20th Mar 2018 8:34pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Hope its sorted 3rd time lucky!!
Maybe avoid remap if engine is suspect. All the best Tommo |
21st Mar 2018 6:00pm |
Update
Picked it up Friday, garage didn’t say what was leaking (I suspect the front crank seal) but all fixed, was going to say no leaks but it has a few small ones, the huge one has been fixed. drove it home and it does really drive well now, however.... Going round corners and bumps I’m getting a rubbing noise now I’m done with garages now so up on axle stands and a good look underneath finds...the plastic, acoustic? Shield that sits under the engine is loose and rubbing on the prop shaft every now and again. A closer look and it looks pretty damaged, not recent though. 5 bolts and a bit of manoeuvring later and it’s out, in two pieces, sodden with oil too. My last 110 didn’t have one and after researching on here it appears not all TD5s had them and a lot have broken so it’s en easy decision to not replace it. The good bit. Drove it to work tonight, 100 miles, and it never missed a beat, sounded good and pulled well, even up some large hills. 100 miles isn’t enough to restore my faith but I think I’ve turned a corner now and it’s going to get some miles on it over the next few weeks. My smile is slowly returning. |
25th Mar 2018 8:17pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Great news
25th Mar 2018 8:21pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1172 |
What he said My confidence has been writing cheques that my abilities can't cash for years. |
25th Mar 2018 10:41pm |
Liam Member Since: 14 Nov 2016 Location: Rotterdam Posts: 32 |
What a saga! Hope three times a charm
27th Mar 2018 2:00pm |
Still running well! I’m thinking of wheels and tyres now so must be over this lol.
30th Mar 2018 10:52pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Nothing better than some retail therapy
31st Mar 2018 8:22am |
