Home > Maintenance & Modifications > Best roof rack for tent
Clark.432
Looking for a roof rack for my defender 90
The plan is to put a roof top tent on it one day. I’m guessing the tent won’t work if you have sides around the rack. Any suggestions would be appreciated.
Post #679588 18th Jan 2018 11:17am
mk1collector
Use roof bars instead. They are lots lighter and easier to install/remove if you need to take it off during the year. 4x4overlander sell some good quality ones Thumbs Up Ray
My build thread
Post #679589 18th Jan 2018 11:19am
JOW240725
As above roof bars or the Hannibal rack with no sides provides a solid lightweight base to fix to.
Nene Overland has 40% off Hannibal racks at the moment. Thumbs Up
Oh and welcome to Def2 James
Instagram @suffolk_rovers
Post #679594 18th Jan 2018 11:52am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
AFRICALAND
Racks and roof bars
http://www.africaland.it/ppdef.htm Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #679612 18th Jan 2018 1:45pm
AJC
I use a patriot one
Post #679649 18th Jan 2018 4:11pm
leeds
Before getting the roof tent what will you be using the roof rack for?
On a 90 the roof is ca. 2m long which will be completely covered by a hard shell roof tent.
With a 1.4m folding roof tent you need room down all sides to get cover on etc. That means you will only have ca.40 cms of rack to use.
I would suggest 2 or 3 roof bars for mounting a roof tent as it will keep weight and cost down. The Cargo bear roof bars are ideal for this and are low to the roof. They can be then added to, too make a full roof rack later if required.
Alternatively a short rack at front and bar at back as well
Brendan
Post #679667 18th Jan 2018 5:41pm
nitram17
These safari equip roof bars are great ..you get two sets
....leeds sells them http://www.4x4overlander.com/product/defen...-roof-bar/ so does the safari equip http://www.safari-equip.co.uk/index.php/ro...racks.html
Post #679683 18th Jan 2018 6:32pm
familymad
Patriot Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #679685 18th Jan 2018 6:36pm
Offroad-Tec
Germany
Roof bars for roof top tent
Hello,
we use these roof bars. You can put it complete with the tent on the roof or fit it in a few minutes (10-15) on tge bars. You can use every type of roof bars for this if you have the correct mounting kit :-.).
Regards - Markus
Post #679839 19th Jan 2018 9:17am
LittleFoot
Bars are fine for most roof tents so long as they have sufficient load rating. Bars which are suitable range from Mantec to Front Runner but also include most of the much cheaper transit van type bars 👍 like ULTI etc.
If going for rack avoid steel (weighs loads and always rusts under the plasticote) and go for a proper Aluminium Expedition Rack.
Tip - make sure any rack you go for has T Slots (captive nut channel system) on ALL the slats and ESPECIALLY on the top of the perimeter frame as it makes mounting accessories far far easier in the future (Front Runner, Hannibal, Upracks, Desert Racks etc)
Post #680258 20th Jan 2018 7:46pm
