Home > Puma (Tdci) > 2.2 engine 'hunting' on startup idle
LCJ
My 2.2 engine doesn't sound quite right to me when you start it from cold. It starts just fine, but when idling for the first 30 seconds - 1 minute sounds like it is hunting slightly, and you can see the revs pulsing slightly too. There is no smoke produced, everything else seems absolutely normal and the car pulls away and drives just fine at all times.
Is this normal or something to add the list when it visits the dealers shortly?
Thanks for any thoughts!
Post #677935 12th Jan 2018 4:57pm
bankz5152
Not sure if related but my old mans 07 l322 was doing the same, turned out to be a dodgy EGR valve.
Post #677941 12th Jan 2018 5:11pm
agentmulder
Kuwait
VCV possibly, although I do wonder how many good ones have been swapped out unnecessarily ... (and how many dud ones remain installed!).
I know that on mine the occasional idle hiccup is only apparent when AC is on, took a while to figure that one out. Solved the bowel problem, working on the consonants...
Post #678018 12th Jan 2018 8:57pm
jst
could be poor fuel? do you use branded or supermarket?
recently was caught short and put in Tesco fuel mpg fell through the floor and it hunted on a cold start cold day. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #678020 12th Jan 2018 9:13pm
LCJ
Thanks all, I’ll mention it to the dealer. Fuel is whatever is best priced and to hand so it’s had a mix of branded and supermarket-it doesn’t seem to make a difference
Post #678236 13th Jan 2018 8:24pm
TOP5N
I have noticed the past couple of days that mine was doing it too (2015 my) i only use premium diesel (v-power diesel or BP Ultimate)
It is very slight but just about noticeable.
Post #679390 17th Jan 2018 7:55pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
^^^^My MY2015 does this as well. Run on premium fuel. I actually notice it more at 'in between temperatures' - not when freezing cold, and not when nice and hot - but in-between these two.... LR have tried software updates which may have helped a bit, but very occasionally I still see the revs fluctuate on idle. My independent didn't think it was VCV and thought most likely to be software related. His words were.... 'its not a Mercedes'..... so I'm not pursuing this anymore, as it runs great and disappears as soon as I blip the throttle. Please let me know if you resolve this. thanks. Jerry
Post #681746 25th Jan 2018 11:01pm
zsd-puma
Do you do a lot of short trips? I find m7 2.4 is noticeably smoother after its been on a good run. It'll stay that way for a few days until it's had a few short trips again.
Post #681760 26th Jan 2018 2:04am
Jerry
Yes, I do lots of short trips which is one of the reasons that I use premium fuel. I understand that the DPF regeneration process needs longer high temp runs, so I minimise the junk deposited by using better quality fuel. I try and get a few longer runs in occasionally to try and help it clean itself. Runs great - just v. occassional slight irratic idle on starting at 'in between' temperatures.
Post #681816 26th Jan 2018 11:00am
Naks
Mine started doing this in winter, with large clouds of white smoke.
Replaced the VCV, and it improved a bit, but didn't go away completely. I did the re-learn, pilot correction, etc., even got the new BAS remap.
My mechanic says the injectors are on their way out even though they were removed, inspected, and sent for testing, which revealed all in spec.
Then summer arrived and the symptoms disappeared, so I will wait until next winter to see what happens... --
Post #681821 26th Jan 2018 11:27am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
maybe need a long run to do the ReGen thing with engine - mine does lots of long runs normally, but I did find that the engine was not as smooth after a week or so of short runs in slow traffic in London... a long drive at 60 back down the M4 and it was right as rain again ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #681823 26th Jan 2018 11:29am
LCJ
Just to update this, it’s been to the dealer who said no fault codes showed and every defender he has seen does it. Plenty of warranty time left so will keep an eye on it!
Post #691798 7th Mar 2018 7:51pm
LCJ
As a further update, the car started choking when throttle was applied on Friday, and eventually cut out and wouldn’t restart. Dealer has proudly said they’ve identified it as the fuel pump, I’m just waiting for a more detailed explanation to see if it was VCV as I suggested when they first had it for two weeks..
Post #694863 20th Mar 2018 8:55am
