Home > Puma (Tdci) > DPF Rattle |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Over the last few months my 2012 2.2 has developed a very rattley exhaust, at first thought it was the turbo heat shield. Investigations proved this not to be the case. Just like old cars it sounds like the baffles have all become un-welded or broken in a silencer, but this is right up front so can only be the dpf cartridge rattling round in the exhaust after the turbo.
Any ideas how to shut it up as it is bloody annoying. I cant just remove it as I work in London and surprisingly enough was stopped a few weeks back for a TFL emissions check outside the old Olympic stadium on the A12, passed the test apparently man said it was lower end of euro 5 band, not bad for a dpf that has done 260 thousand miles. If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
14th Jan 2018 7:58pm |
Both the heat shields are not in the greatest condition but I have wedged them and tied them so its not them. But the noise is very loud rattling and goes with revs once forcing gas through it. If everything is under control you are not going fast enough.
22nd Jan 2018 10:11pm |
