Home > For Sale & Wanted > [Wanted] Heavy duty rear crossmember |
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 746 |
I've got a standard 200 tdi crossmember for sale.
It came from a chassis swap I did, chassis was shot but it had had a replacement xmember to get it thru an mot before I bought it. I scraped the chassis but kept the xmember. Any good? |
14th Jan 2018 2:54pm |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 173 |
There’s a short thread here...
http://www.defender2.net/forum/topic36148.html?view=previous I’ve not had mine done yet but will look at getting it done later this year. Still looking at the RCP Raid version to avoid the usual muck traps. 2002 Defender 110 CSW TD5 |
14th Jan 2018 4:52pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1227 |
I had a very heavy duty one built up for me by Luca at CLH Trailers in Wales. C section style out of 5mm wall with another 6mm thick section welded behind the tow bar mounts. Only difference from the rear is there are fewer holes and less rust than standard. Can try and dig out some photos if you want. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
14th Jan 2018 6:37pm |
joe dirt Member Since: 11 Mar 2012 Location: Staffordshire Posts: 131 |
Thanks HK07, but i was after something new really
thanks joe |
15th Jan 2018 7:47pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
I've bought parts from these guys and have always been impressed with the quality https://www.racpartsltd.co.uk/defender-chassis 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
15th Jan 2018 8:47pm |
djgg Member Since: 22 Apr 2013 Location: Southport Posts: 22 |
I have a blacksheepcrossmember.co.uk
My opinion the best cross member made, no mud traps, made from 6mm steel. Easy to fit and great customer service. David |
15th Jan 2018 11:20pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
That's what I want when mine needs one. But without the recovery loops to make it compatible with the NAS step. |
16th Jan 2018 12:17am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Is he still trading? 1951 80" S1 2.0
16th Jan 2018 5:50am |
i tried to call Blacksheep yesterday and but it didn't ring
16th Jan 2018 6:29am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I spoke to him at the end of 2016 and he was winding up production of the crossmembers. He had enough stuff left to do two, i bought one and i guess the other is long gone.
A real shame as they were superb and Clive was a great guy. Steve 02' 110 TD5 Double Cab Rebuild Thread |
16th Jan 2018 7:05am |
Cheers Harry.O, I rang RCP today very friendly, going to pop down and have a look they do they standard 2mm and a 3mm crossmember so Iam going down next week to have a look
16th Jan 2018 1:51pm |
pressbrake Member Since: 06 Oct 2012 Location: essex Posts: 31 |
I still have a machine shop but I stopped landrover stuff in 2016 I fitted nearly a thousand over twenty odd years so Ive done my bit! There are some ideas still left but corrosion repair is not one of them |
12th Apr 2018 6:37pm |
texpis Member Since: 13 Jun 2009 Location: Stockton-on-tees Posts: 52 |
This chap does some heavy duty crossmembers
https://dixonfabrication.co.uk/index.php?r...=87_89_111 Mick |
12th Apr 2018 7:27pm |
Hi all, i got one from RCP and it is a spot on, fits nice and snug, exellent quality , in 3mm as i asked for, i can't recommend them enough i will be using them from now on as all the others i looked at were not a very good build quality
13th Apr 2018 7:25pm |
