Home > Technical > Annoying intermittent electrical fault... |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
CPS playing up🤔
4th Jan 2018 10:53am |
Andy730 Member Since: 12 Dec 2017 Location: Douglas Posts: 45 |
Thanks for the reply..
I've skipped through the manual... What is the CPS...? i cant find it mentioned anywhere.. Andy 2007 Puma Defender 2005 Volvo S60 T5 (for Sundays) 1998 MGF |
4th Jan 2018 3:18pm |
Crank position sensor
4th Jan 2018 3:20pm |
OK, thanks.. that kinda makes sense... But would that kill the rev counter and other electrics etc...? Andy
4th Jan 2018 4:48pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17361 |
Check that the relays under the driver's seat are really secure in their sockets. Many starting and running issues on the 2.4 can originate from one or more of the contacts on (in particular) the main relay being loose.
I don't know if Hawkeye can turn off PI, but turning off PI is one of the biggest improvements to starting performance you can make. It doesn't seem to be a particularly reliable feature (though admittedly many people have no trouble) and it really doesn't significantly reduce the security of the vehicle (the immobiliser is activated when the doors are locked regardless of the PI). |
4th Jan 2018 5:23pm |
OK thanks, I checked all those relays in December, but no harm double checking as it would be very nice if it was that... Andy
5th Jan 2018 12:03am |
I have pulled the main relay, and i took the top off it. The contacts looked OK, but had some small marking from what looked like contact bounce.
I simply rubbed the contacts with brown cardboard, refitted the cover and refitted the relay. Since then (i say with my fingers crossed) all has been ok. But just to be on the safe side, i have rejoined the RAC. I guess time will tell, but i'm using it as my daily hack, so if somethings going to fail, it'll have more chance... Andy 2007 Puma Defender 2005 Volvo S60 T5 (for Sundays) 1998 MGF |
9th Jan 2018 4:11pm |
Well, that didn't take long...
took the car for a short 2 mile trip this morning, i got about 800 yards and, although the car kept running and driving, the instrument cluster died. i.e. the rev counter, speedo froze, the green LED window died. No other lights were on the dash at all. Even the yellow engine light went out LOL (that's lit for the faulty EGR that's on the cards to be sorted) I got to where i needed to be and stopped the engine. Bizarrely the handbrake light lit up, but in a half power (i.e. dim) When i came to restart the car it wouldn't go... the same symptoms, it would turn over for a second or two then just die, then the next try it wouldn't even try to turn over... So.. with having just changed to key switch, i left the plastic cowlings off the dash. (top & bottom) I found that i could press and move the harness as it plugged into the dash, doing this actually affected the dash lights. I managed to get it so that i could start the engine. As such, i returned home. Now that i'm home, I have found that with the instrument cluster unscrewed i could pull the harness and this killed the power to the dash itself. What i've yet to figure out is this; is the bad connection on the plug to the dash, or is it down behind the dash itself. Right now i'm not sure where the harness goes once it leaves the instrument cluster... Any hints or advice on that?? Andy 2007 Puma Defender 2005 Volvo S60 T5 (for Sundays) 1998 MGF |
10th Jan 2018 10:09am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2224 |
I'd be inclined to disconnect inspect and reconnect all the plugs and see if that makes a difference.
10th Jan 2018 3:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20325 |
Remove, clean, re-tighten main earth strap on transfer box.
Sounds like a 'common' electrical issues, earth is common in the electrical system hence it possibility of cross linked issues. It can have all sorts of bizarre effects. Worth checking anyway. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
10th Jan 2018 4:36pm |
Just adding a note here about this short thread as i've (with help & advise from others) found the problem and fixed it..
There is a complete thread on this forum about it here: http://www.defender2.net/forum/topic59938.html Just in case someone finds themselves with the same fault. Hopefully, these two threads will be of help. Andy Andy 2007 Puma Defender 2005 Volvo S60 T5 (for Sundays) 1998 MGF |
12th Jun 2018 7:04am |
