Home > Puma (Tdci) > Door Vent upgrade
dgardel
Italy
Door Vent upgrade
Could be a good upgrade?
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #677150 9th Jan 2018 10:53am
bankz5152
Link? Could be a perfect vent mod for my TD5 Very Happy
Post #677153 9th Jan 2018 11:05am
ibexman
Good find Dan
Post #677163 9th Jan 2018 11:34am
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Here you go, 1 of many links you'll find if you shove 1320206 and webasto into the old search engine
https://www.ebay.co.uk/p/Webasto-Air-Top-H...2284718020 Thumbs Up
Post #677186 9th Jan 2018 12:56pm
bankz5152
Awesome! Thank you! I was going to use Puma side vents but I was concerned on how secure theyd be. These would be a lot better!
Post #677193 9th Jan 2018 1:32pm
under_rover
You're welcome.... But before you put your hand in your pocket there are some cheaper solutions to be found here http://www.defender2.net/forum/topic33126....=demisters
Post #677203 9th Jan 2018 2:27pm
MK
Defender lacks of proper vents on the front sides Puma 110" SW
Post #677208 9th Jan 2018 2:56pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Re: Door Vent upgrade
I don't see the benefit of this upgrade?
Post #677219 9th Jan 2018 3:43pm
zsd-puma
Pre-Puma Defenders don't have any vents to demist the side windows, this would make adding them a little easier.
Probably not much if any benefit on a Puma though.
Post #677257 9th Jan 2018 6:38pm
bankz5152
Ive seen that thread, though I wanted a neater more OEM looking solution which this provides, going to use it in conjuction with the MUD vent 2.0, so I can adjust the direction too! Very Happy
Post #677265 9th Jan 2018 7:07pm
