Home > Off Topic > Bass Guitar
jonesfrm
Bass Guitar
Sorry this is really off topic but does anyone have any experience with making guitars... particularly electric basses? I've just started a project for a 6 string, just like to know if anyone has built any guitars on here and a bit of their knowledge!
Thanks,
Jones
Post #675933 4th Jan 2018 10:44pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
In 1975 when I was 15 I built a P bass out of some wood my step dad had been saving for another project!
Since it did not have a truss rod I kept it fret-less as I knew the neck would warp over time. Some 44 years later it still works and makes a reasonable tone. I went on to play a Fender Jazz fret-less in a couple of bands.
Recently I have bought a new Fender Jazz with maple neck and frets!
I too have been thinking about building another guitar. I found a youtube channel for "Crimson Guitars". You will find Ben has all the knowledge and there are some fantastic build tutorials there.
Try this link.... https://www.youtube.com/channel/UCdD1Cqxr8aINzWs1agg3tEQ
Good luck! Cheers Don.
Post #676004 5th Jan 2018 9:36am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Yes, I've built several basses over the years. This one still gets regular use 30 years on:
Recently I've assisted my son in building a Telecaster kit and making a new body for an existing guitar neck:
My best advice for domestic harmony is don't do this:
Post #676027 5th Jan 2018 11:40am
ibexman
Rolling with laughter Rolling with laughter I bet the wife wasn’t happy
Post #676028 5th Jan 2018 11:44am
jonesfrm
Rolling with laughter Rolling with laughter that doesn't look ideal!
Did you put together your own fingerboard?
Absolutely love that straight thru neck they do look very nice! I am actually thinking of making mine out of spalted maple... not sure if you have heard of it but it does look superb!
I was thinking of a fretless as I do not have coil or anything. How long did it last for before it warped too badly?
Post #676148 5th Jan 2018 5:53pm
Intercept
Yes, the fingerboard was an AAA grade ebony blank from a luthiers timber supplier, planed to a 12" radius then fitted with frets. The next fret position is calculated by dividing the resonant length by 17.817. To prevent neck warp from unstable timber you'll need to at least cut the blank in half lengthwise, reverse one half end to end, then bond the two halves back together. Then shape the neck with a spoke shave. Multiple reversed laminations are even more stable - hence the stripy thru neck in the photo. You should fit a truss rod to allow you to pull the neck back to counteract the pull of the strings. Truss rods in aluminium U channels are readily available and easy to rout into the neck before you attach the fingerboard.
https://www.touchstonetonewoods.co.uk is a useful supplier.
Hope this helps!
Post #676252 6th Jan 2018 12:53am
