Home > Td5 > TD5 possible performance issues
Djcla
Ever since ive had my TD5 ive found it a little sluggish in the gears and it will struggle on hills in 3rd/4th if i dont get a run up. I have the 15p engine and compared to a friends 10p his is definitely more responsive through the gears but has about 90k less on the clock. i tried running with disconnected MAF and it seems a little better but not much and might be in my head. One thing i do notice it there is a slight whistle as you accelerate past around 40mph which is more noticeable as you get up to 60 etc. I do wonder if its an issue with the turbo or hose of something as there is a definite lag .
Any ideas what to check for? i have nt plugged in my trusty odb2 BT dongle and used the torque app yet as there is no engine light on the dash.
Post #675112 2nd Jan 2018 10:36am
bankz5152
Check the usual
- oil in the red plug of the ECU, if so then replace the injector harness
- Clean the MAP sensor on the inlet manifold
- check for blockages in the air intake
- check for any leaks/splits/delamination of the turbo hoses
- check the wastegate on the turbo is free, lube up anyway
- check the EGR isnt blocked if fitted. If not then blank off anyway
- is the MAF sensor genuine?
Post #675129 2nd Jan 2018 12:05pm
Djcla
thanks ill look at all that , ill have to work out where each item is first as im a newbie at this stuff but learning Smile How would i tell if the MAF is genuine is it obvious looking at it?
Post #675131 2nd Jan 2018 12:16pm
grafty99
Genuine ones will have VDO Siemens marking on them somewhere. If replacing only replace with genuine Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675136 2nd Jan 2018 12:24pm
barbel jim
The whistle could be from a warped exhaust manifold, but should do it at related engine revs as opposed to speed. Look for soot marks on the engine side of it. Whilst checking the hoses, make sure all the clips are tight and they haven't slipped back.
Post #675141 2nd Jan 2018 1:11pm
bankz5152
ECU is under the drivers seat
Injector harness is under the rocker cover, top of the engine. Very easy to change
Inlet manifold is on the left of the engine if looking at it face on, sensor is in the middle
Locate the turbo on the right hand side of the engine, follow the soft rubber hoses thru the engine bay
Check google for pics
Plenty on youtube for this one. Landrover toolbox videos are a great way to learn.
Post #675174 2nd Jan 2018 4:17pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
My td5 was slightly sluggish but the alternator died which was replaced as was the battery and then added one of those engine additives but now she flies....but not sure why Confused
Post #675461 3rd Jan 2018 5:22pm
Djcla
My alternator belt squeels when cold but seems to fix itself when warmed up.
Post #675462 3rd Jan 2018 5:24pm
Djcla
It might be more of a wurng kinda noise hard to describe tbh.
Post #675464 3rd Jan 2018 5:26pm
Djcla
Hi
I'm convinced the MAF is duff on my car it makes little difference if it is connected or disconnected. It's getting power I've checked that on multimeter. How do I tell if it's duff or not though for sure? I saw a video showing to disconnect it while engine running and if engine stalls it's working, is that right or will I do damage?
Post #682408 28th Jan 2018 8:00pm
