Home > Puma (Tdci) > Nugget stuff intake and LR RAI - help
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I have purchased a Nugget Stuff sealed air intake system but have an issue
I have a LR RAI and on trying to refit it to the nugget intake on the wing have just noticed the bottom clips of the LR RAI can now not clip over as the nugget intake is too shallow.
What has others done - I can see no option but to cut the feet/clips off the LR intake (one i can leave 5mm the other will have to be cut off) and just sikaflex the intake to the wing, obviously it is still help in place by the upper two bolts
Advise would be appreciated
Ta
Post #674093 29th Dec 2017 2:54pm
jst
i cut 2-3mm or so off the feet on the metal clip of the RAI, heated them up and then fitted it so they melted down into the nugget box. been like that for 19mths no and no probs. its still sikaflexed to death Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #674159 29th Dec 2017 6:23pm
Iktank
Thanks for your reply, Landy still on the drive with no RAI re-attached, going to finish it off today and cut the tangs down so it clips over by about 7mm (cutting off about 10mm)
I will have to attack the nugget plastic with a dremel to provide sufficient depth to receive the clip, the front one I will need more trimmed than the rear as the clip lines up with a rib
Once all done gona call up to Dia Walters Arena and have a play in the mud and water
Post #674616 31st Dec 2017 10:51am
jst
dremel is one way, heating it up and letting them melt their own path also works very well. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #674812 31st Dec 2017 9:23pm
familymad
Ordered one of these yesterday .... sounds like another fun job 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #674839 31st Dec 2017 10:45pm
Welshsurferdude
Wales
Got no snorkel on mine and been to walters a few times I wouldn't worry too much Smile just have your sensible head on when near water lol Rolling with laughter 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #674895 1st Jan 2018 10:45am
familymad
We are always out single vehicle so I am quite risk averse near extreme terrain or wading. Always 3 children with us too so not planning to get stranded if I can avoid it! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #674896 1st Jan 2018 10:48am
