Home > Puma (Tdci) > Window gasket |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
I'm interested to hear people's thoughts on this too.
Welcome to the forum, 110. |
14th Apr 2011 9:56pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
The windscreen to bulkhead seal is a very common source of leaks. Unless you want to raise the hardtop and separate the screen frame from the bulkhead one way of tackling the problem is to run a neat bead of good quality sealant along the join and as far inside as you can get once you've temporarily pulled the door seals away. Steve.
15th Apr 2011 5:43am |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
Perhaps no more info than Miserableolgit has mentioned. You can buy a like for like replacement foam seal on eBay for around a fiver then it's just as above separate the hardtop/windscreen from bulkhead and replace seal! Apparently alot of work. I'd be keen to see if anyone has under took this as a DIY job with any tips. It's a job I wanted to do a while back but chickened out Sweep
2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
15th Apr 2011 6:24am |
110 Member Since: 07 Apr 2011 Location: Nottingham Posts: 43 |
Are there better seal around? Is it just a case of losening the 4 bolts on each side near the door and rainsing the windscreen a few mil, pull out th eoriginal then insert the neww one? 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
15th Apr 2011 6:57am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
It certainly shouldn't degrade in that short time,is the screen tight on the seal ?,it's not an easy job to replace as you have to raise the roof at front to gain access to it,as previously mentioned.
good luck 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
15th Apr 2011 7:10am |
It's just a closed cell foam strip with adhesive tape on two sides - nothing special and available from lots of places (think trim and body supplies) either on a roll or by the length. I've replaced them on pre Puma Defenders before but would still run a bead of sealant around the joint new seal or not. Steve.
15th Apr 2011 9:21am |
you could try loosening the clamp bolts each side if the screen, get someone to sit on the front of the roof and retighten,this has been done by a guy on here and it stopped the leak. 2.4 90 XS
15th Apr 2011 10:51am |
I think I'gg with the silicone route. Do you guys recommend any good BLACK silicone? I also nottinced that the lip that truns along the windows sill is a couple of mm up to the middle section. I.e it seems ity is made of 3 pieces and water may be coming through that way. 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
16th Apr 2011 2:30pm |
