Home > Maintenance & Modifications > Fitting a side fuel tank to 110
Page 2 of 2 <12
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
lrmaniac wrote:
jst wrote:
...only issue is the output which feeds the main tank is not at the bottom of it, hence requirement for a balance pipe.
what is balance pipe ? Embarassed ....I'm thinking of acquiring one aux fuel tank very soon....
It's a pipe cunningly designed so that should you get a hole in one of your tanks it makes sure both/all your tanks empty themselves on the floor.
Post #145538 17th May 2012 2:06pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Thumbs Up Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #145554 17th May 2012 3:54pm
TJ101
jst wrote:
if the output from the aux tank to the main tank is not at the very bottom of the aux tank you end up with a residual amount of fuel - 5-8L on a side tank? stuck in the aux tank below the output.
Old thread but to update,, The remaining fuel in the aux tank, below the outlet to main is 13 lts for the Front runner aux tank California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #672298 20th Dec 2017 5:46pm
jst
surprised me when you said that the other day too, now a way to get that out without an exposed Balance pipe..... or drilling into main tank below the chassis!. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #672538 21st Dec 2017 8:38pm
TJ101
Actually, its not that exposed, as the forward mount bracket covers the balance pipe outlet, (as i have used, not as a balance pipe, but feed for the Webasto) If needed, i can get that last 13 lts out of the aux tank California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #672544 21st Dec 2017 8:46pm
jst
i meant the other end of the pipe being exposed as it would need to enter the main tank below its aux exit point which seems to mean below the chassis rails as chassis is in way of anywhere else. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #672636 22nd Dec 2017 12:00pm
Page 2 of 2 <12
