- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Willbof
Hi all, after refuelling my 2012 tdci I got a check engine light up. Cycled the ignition but no joy so popped into the nearest garage and try plugged it in. Apparently my oxygen sensor has failed. No biggy I thought, so came home and loooked it up. I’m struggling to find the info I was sure I was going to get. Some descriptions say there are 4 of these in there somewhere and I didn’t take note of which one i had a problem with. Is it true that there are four? I can only assume they’re all over the dpf rather than your standard old lambda sensor type.
20th Dec 2017 12:25pm |
dorsetsmith
20th Dec 2017 12:56pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
