![]() | Home > Technical > Headlights |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Sounds like the pink (headlight) relay behind the dash has failed. same happened to mine except when switching from main to dipped beam which was interesting
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 19th Dec 2017 8:18pm. Edited 1 time in total |
It is possible to bridge the terminals with wire and a couple of spade terminals as a get you home fix
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
Which terminals do I have to bridge? Where abouts is the pink relay behind the dash?Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
I'm not sure on a puma, there is an image somewhere I've seen. I'll see if I can find it
Stolen from a previous thread on here. It is the dim dip relay but it does affect the normal headlights
![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Where abouts are these on a 2011 puma, I can’t find mine behind the dash. Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
I'd have thought behind one of the flaps either drivers or passengers footwell. But I'm not sure as I never looked when I had a puma 2002 90 Td5 Station Wagon
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
I don't think there is either a dim dip relay or a headlight relay on a puma, hence the column switches fail.
New column dip/main indicator switch and one of the advertised headlamp loom upgrades probably required. HTH Keith |
Some puma's definately have dim dip
Problem solved 😁 my suspicions were correct, it’s the flash/ indicator/ horn switch the plastic has melted and is keeping the contacts apart, bent the contacts slightly to get me back on the road while I get a new switch. And yes just to clarify I did find the relay that’s in question and tested it but all was well, it’s in the fuse box under the dash. thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Nice one
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Symptoms are conclusive that it's the dip/main/flash stalk switch.
Pumas without headlight level adjusters (ie all the early N1 type approved vehicles) had the abhorrent dim dip feature, the relay is in the fuse/relay panel above the driver's feet and the resitor is under the osf wing. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Non-Dim dip ones also have the relay, however all it does is cuts the power to the headlights when you turn the ignition off. Whether you have Dim-dip or not the full power still goes through the column switch.
Just think, when we leave the EU the UK Department for transport will be free to reintroduce crap features like that. Originally the DfT wanted all cars in the UK to have dim-dip, the EU overruled them as it would have introduced disparity between europe wide type approvals, hence you don't find it on any cars built outside of the UK. |
Just for future reference, does anyone know what the other 6 relays are for in the dash fuse box? I have a diagram for the ones under the drivers seat. Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
