Home > Maintenance & Modifications > Which shocks?
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Which shocks?
I need some advice here from people with experience. I have a TD5 90 pickup and am going to be changing my suspension. I am looking at changing my shock absorbers and wanted some advice. At the moment I am deciding between De Carbon and Bilstein and wanted to hear from people with experience. I have run De Carbon before with Scorpion Racing springs and I enjoyed a wonderful ride but that was on a 110 and I fancy a change. I am not interested in Old Man Emu as I have several friends who have used them and have had issues with build quality and don't rate them anywhere near as high as Koni. I don't need anything as heavy duty as the Koni ones as I am not using my vehicle for expedition work, purely road, farm tracks, offroad play days occasionally etc
Post #67098 13th Apr 2011 7:45am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Standard Springs and adjustable Koni shox on my 90 , big improvement in the ride quality.
Don't under estimate the quality of the standard springs, unless you need a lift or want heavy duty , I would save my money on the springs and put it towards a good set of shox.....
Koni or Bilsteins for me.
Only negative I found with the Koni shox is the rubber bushes not wearing very well but thats any easy fix .
N.
Post #67099 13th Apr 2011 7:58am
farmer giles
i agree with nidge.
i had konis (lowered by 1 inch) on my 300 Tdi 90 Hardtop and it is the best handling land rover i have ever had (owned 11). I still enjoy driving it even with my 110 puma on the driveway!
i have only had to replace one shock in the 12 years of ownership when it sheared at the eye. it was regularly taken green laning and always did the intermedeiate course at Eastnor.
not experienced the other shocks but highly rate koni
Post #67109 13th Apr 2011 8:47am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
another vote for Koni Heavy Tracks. i don't tend to run heavy loads and they are still great. BM52
Post #67211 13th Apr 2011 7:46pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
My Bilstein work great and i tow heavy everyday Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #67214 13th Apr 2011 8:04pm
mse
Ive found that none genuine springs start well but dont last as long.
Genuine springs (heavy duty or not) and good quality shocks. Mike
Post #67239 14th Apr 2011 6:40am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
got to be koni heavy tracks, adjustable and come with a 2 year warrenty Very Happy 2004 TD5 Defender 90 xs station wagon
Post #67688 17th Apr 2011 5:22pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
How do you adjust the Koni's? Do you have to remove them or can it be altered on the vehicle?
Pete
Post #69243 1st May 2011 7:09pm
bm52
have a look at the Koni web site re adjustment, quite easy.
the rears can be adjusted by undoing the bottom and the fronts [not tried it] but i think if you undid the bottom and the turret ring you can pull them out quite easily.
i'd be interested in your chosen setting. i run mine on the factory setting which is the softest. BM52
Post #69249 1st May 2011 7:30pm
johnszs
i beleive mine are set to medium which i was told is the std, but they give a nice firm ride on the road and seem to take everything offroad whilst retaining reasonable comfort Laughing 2004 TD5 Defender 90 xs station wagon
Post #69343 2nd May 2011 2:46pm
Alive Tuning
I have tried various damper types when setting up my Td5 90 for fast road use, prior to the HBE kit being made. I use Bilstein on everything as they are good value, last well, and give an outstanding ride quality.
I've never been a fan of adjustable dampers being used by joe average, as it can be potentially dangerous to tweak them yourself, upsetting the balance of the vehicle. Bilsteins come with a fixed rate, which is in my opinion, just right.
Post #69365 2nd May 2011 5:46pm
