Home > Maintenance & Modifications > Chequer plate sill fitment - gasket, silicon or Dinitrol wax
dickbowyer
United Kingdom 2011 Defender 90 Puma 2.2 SW Epsom Green
Going to fit Mammouth chequer plate sills to prevent ongoing sill damage from boots when standing on side steps. Paint all intact. No gaskets supplied so are they not need, best fabricated from pond liner material or will a coat of Dintrol wax do the trick to prevent corrosion between sill and CP. If so which Dinitrol to use? Sorry to ask Whistle but not clear from previous threads. Will of course Dintrol bolt fitting holes and rear nuts.
Post #670825 13th Dec 2017 11:26pm
mk1collector
I dinitrolled Inbetween my cp and sill and as you say the back of the sill too Thumbs Up Ray
My build thread
Post #670839 14th Dec 2017 12:19am
dickbowyer
Which type of Dinitrol, seems to be many formulations. The high performance wax?
Post #670859 14th Dec 2017 7:50am
Last time I fitted a set, I stuck some self-adhesive closed cell foam, 2-3mm thick, to the back of the CP, which worked well. There shouldn't be a corrosion issue between the two panels as they're both aluminium, but it stopped crud building up between them.
I also secured them with 6mm nylon nuts and bolts. There's little to no load on them, even if you bash the cills, and they avoided rusted bolts. It could also be done with stainless bolts and nylon washers to separate the metals if you wanted to. I've got quite a collection of different sized nylon washers now, as they're really handy for this sort of thing. Darren
Post #670861 14th Dec 2017 9:10am
Grouse
I am going through this same scenario with the bonnet on my 110. But I am going to stick it on with TigerSeal and also rivet it. No corrosion, not coming off and therefore won't create any issues
Post #670906 14th Dec 2017 4:58pm
