![]() | Home > Maintenance & Modifications > Switch surrounds/holders |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 ![]() ![]() |
Any one know where I can get the below from?
Mcma1 on here made them but I haven't seen him around much since he sold hi defender. Ray
Firstfour do them as well https://www.firstfour.co.uk/defender-double-switch-bezel.html
Thanks geobloke!
Question is does anyone do them for the Hazard switch? |
The disco 2 hazard switch fits them Ray
Thanks, I guess that will mean a load of wiring for the hazard switch?
I've not done it myself but I'm sure it would just be a case of taking the pins out of the defender wiring plug and putting them in the correct order on the disco plug. Ray
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I believe it's a fair bit more involved than that as the disco switch controls the BCM and not the lights directly. Relays etc required I believe. I'm sure there was a topic on here somwhere
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Here it is
![]() http://www.defender2.net/forum/topic42402....p;start=15 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Not quite as easy as I thought then Ray
Unfortunately not
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
I'm sure that I've posted this before - but, can't find it ![]() Here it is again - ![]() Click image to enlarge The D2 switch has been modified with the addition of a 12v 5mm Red LED, wired across pin 5 (warning flash live) and pin 4 (earth), as in my post here - http://www.defender2.net/forum/topic42402....p;start=15 Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 3rd Nov 2019 8:48pm. Edited 1 time in total |
Ideal! Thanks for that
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
Paul Mc made mine and it was one of the best things on mine.
He modified the D2 switch to flash and made up the whole relay bank, was a shame to hide it away, it was that well made. Paul.... where have you been? I was after a few looms for ages? |
