Home > Wheels & Tyres > Extended wheel arches |
Dutch G4 Member Since: 29 Jan 2015 Location: near Rotterdam Posts: 49 |
Since last Saturday i am the owner of this Keswick green soft top with extended wheel arches (see also my topic in the Puma section). I want to buy an extra set of rims 'Wolf style" and have these painted in Keswick green - i very much like "full" arches so i'm looking for rims with a complete different offset than the boost rims, current tire size is 265/75-16 with 30mm spacers, but i would not go wider than 285/75-16 like i had on my previous Defenders.
Can you help me with the offset, what do i need to fill the arches more ? I have seen these weels from Raptor with offset 0, they seem wider but i have no idea which offset to choose ..... http://www.raptor4x4.co.uk/raptor-4x4-wolf...-et-0.html Many thanks for your help / advise / suggestions Click image to enlarge Click image to enlarge Click image to enlarge Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
4th Dec 2017 1:37pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 |
Ive got 0 offset Bowlers with 285/75 tyres + 30mm spacers, fills the same arches perfectly
4th Dec 2017 1:44pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I thought the 16" Bowler were ET15? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
4th Dec 2017 2:36pm |
I believe (but not 100%) the widest tyre on a 6.5" wide rim would be 265mm. The Wolf 'style' rims with ET0 are also available st 4x4tyres for much less https://www.4x4tyres.co.uk/16-x-65-tuff-to...0-%202016) James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
4th Dec 2017 2:41pm |
Mis typed! 10 offset not 0 sorry. If you check Coopers website they list the minimum sizes. |
4th Dec 2017 4:35pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
I know they aren't exactly like a wolf rim but have you considered modulars? Pretty cheap and available in all manner of offsets. You could get them sprayed Keswick Green. I've got a set of 16 x 8s with neg 32 offset and they push the tyres out quite a bit.
Click image to enlarge 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
4th Dec 2017 4:49pm |
Bankz5152, So with offset 10 + 285/75-16 and 30mm spacers your extended arches are filled ? If yes then that is the combination i need Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
4th Dec 2017 4:52pm |
Thx for the pic & info Harry, yes i have been looking at modulars as well but i first need to know for sure which offset is the best in combination with the extended arches..... i like the look of your modulars very much Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
4th Dec 2017 4:59pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Twisted 18" on a 0 offset with 275 70 18 (33" overall) fill the archs and abit, they would be great with the wide arches though 2004 TD5 Defender 90 xs station wagon
10th Dec 2017 9:08pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Dutch G4 that is one nice looking defender 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
10th Dec 2017 9:34pm |
And now the difference with 16x8 modulars offset 0 and tyres 285/75-16; 30mm spacers are also still on and now the arches are filled perfectly;
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
17th Dec 2017 12:26pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 |
Looks spot on Clayton.
17th Dec 2017 8:38pm |
