Home > Maintenance & Modifications > Identify these connectors. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Looking at the pictures in your gallery, They look like a single pole welding type connector, never seen anything quite like them though! Where do they actually connect to?
10th Dec 2017 4:00pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
They are dinse connectors, same as used on welding sets for the return (earth leads) 👍🏻 NO ROAD..........EXCEPT FOR LANDROVER
10th Dec 2017 4:05pm |
davybull Member Since: 10 Dec 2017 Location: Wigan Posts: 54 |
Cheers Guys.
Don't know where they connect to yet, haven't had a chance to look!! Will trace them when I have a mo. Dave. |
10th Dec 2017 4:14pm |
OK there seems to be a permanent 12v supply.
Holes are just over 12mm so that means that the connectors are Dinse 35-50 plugs(Cheers for the info Harry). They push in and twist to lock them. Just ordered a couple of plugs off Fleabay but will check the wiring before I do anything. Dave. |
10th Dec 2017 4:30pm |
