Home > Maintenance & Modifications > Side windows |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
As anyone got information on fitting side windows, the bonded type like the puma, need to know where they are bonded and I believe there are small plastic spacers.
Many thanks Last edited by tolley on 2nd Nov 2017 1:04pm. Edited 1 time in total |
2nd Nov 2017 7:37am |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
I fitted side windows from Masai 4x4 in my puma 90 HT - they are a mixture of rivet and bonded (to seal). if that's what you mean then I can help with info, if not then I have no idea sorry! My 90 Project : http://www.defender2.net/forum/topic52774.html
2nd Nov 2017 12:40pm |
Yep that's right, are the puma ones just bonded.
Can't seem to find anything on Web, regarding fitting. |
2nd Nov 2017 1:06pm |
I had a load of holes to drill on the side of the truck (thu the predrilled holes in the frame) and pop riveted in place. You also use some glue to bond and seal it. My 90 Project : http://www.defender2.net/forum/topic52774.html
2nd Nov 2017 1:11pm |
2nd Nov 2017 1:15pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
When I bonded mine in, there is a foam tape around the edge of the outer frame, I used tiger seal bead on the inside of the foam. Then used wooden wedges between the ali side panel and the internal window frame return/ flange.
24 hrs to cure then remove wedges |
2nd Nov 2017 8:40pm |
Thanks foxyred,sorry for the delay replying, that sounds just what I was thinking , I've got some small plastic spacers with mine , thanks for info
Did yours seal good .? |
15th Nov 2017 6:51pm |
yes seal is water tight and bonded perfectly
19th Nov 2017 9:49pm |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 |
Bought side windows from these guys , waiting to receive they are to be bounded
http://www.explore-glazing.nl/de/ Cheers Happy Travel www.thegippo.wordpress.com |
9th Dec 2017 2:22pm |
nice one got any photos
9th Dec 2017 6:06pm |
Hi
Not yet will get it next week from Holland but you can see here the final result in this YouTube https://thegippo.wordpress.com/2017/12/04/...lazing-nl/ Hope it helps Happy Travel www.thegippo.wordpress.com |
10th Dec 2017 12:57am |
