Home > Technical > Assembling the rear hub |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
I have assembled my hub but I'm concerned I may have muddled the order up. I have a W reg Td5 110 with a Salisbury Axle and disc brakes.
I changed the seal on the back of the stub axle. Then the hub went on with (from inside to outside, Seal, bearing race, race outer, tube spacer, race outer, washer (with a flat on inner), staked nut. I did this up to the 210Nm and noted that the hub moved but had some resistance. So could someone confirm I have it in the right order of stuff? I couldn't find a picture of it in the HBoL or RAVE. |
4th Dec 2017 7:28pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4790 |
That sounds right to me 2002 90 Td5 Station Wagon
6th Dec 2017 11:13pm |
