![]() | Home > Puma (Tdci) > Turbo temp fault |
pkrynicki1984 Member Since: 06 Dec 2017 Location: stoke on trent Posts: 8 ![]() ![]() ![]() |
Have seen similar threads.
When cruising on a run my turbo seems to stop boosting altogether. seems to turn into a gutless old diesel , resetting the ignition cures it but it happens soon after. Engine management light is on. 2007 2.4 tdci |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
have you checked the air pipes for splits its a common fault
will do thanks.
seems strange that a reset sorts it out. |
Sound more like electric problem with turbo controls ( Actuator vane) VGT if you can reset by switching ignition off
and no high pitch air sound and lots of black smoke from exhaust ![]() plug the diagnostic in and read fault codes loge in ECM this will help you track down you problem work shop Manuel below for 2.4 engine https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7 |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
See my thread on temporary turbo failure.
I thought initially that my problem was a heat problem but I had no change in temp & no warning lights. In your case I would remove the MAF sensor & wash it off - plenty of info on this site & see if that clears the problem. Meanwhile I will be investigating my problem Guy May your life be like toilet paper ; long & useful. |
Thanks for that.
Many thanks for that.
I'll give it an inspection later , would it still make sense a ignition reset cures my problem ? usually for a very similar amount of time until the turbo dies again? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
It is possible, if, for example, something is intermittently grounding and causing a fault, then un-grounding.
