Home > In Car Electronics > Passenger rear tail light |
Is the LED unit a bulb or a complete unit like you get in the LED upgrade sets?
Are you getting 12v to the plug or unit? |
29th Nov 2017 4:32pm |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 |
Wipac unit and the brake light part works havbt had chance to test yet
29th Nov 2017 4:35pm |
check connect behind Rh rear trim panel the Passenger rear tail light wire links up with the trailer socket at this point
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20504 |
Have you checked Earth continuity and for voltage using a Multimeter?
From there, you can roughly I.D. The issues, and start to trace from there. It could possibly be high resistance on the connector pins also, ensure they are clean and dry. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
29th Nov 2017 4:39pm |
Just put test on and im not getting 12v to the plug Ive checked and tested all fuses inside the cab and cleaned the earth that comes off the three plug loom and bolts to the bulkhead.
Any ideas where to look next |
8th Dec 2017 5:29pm |
Is there a connector to join? |
8th Dec 2017 5:39pm |
8th Dec 2017 6:23pm |
So its already joined? Ive just been reading your old posts, i think i might have alook behind the dash
8th Dec 2017 6:37pm |
