Home > For Sale & Wanted > [SOLD] Driver Door Hinges |
A pair of good, used, later type drivers door hinges. I bought these as part of a vehicle set but I'd already replaced these ones. They are a direct replacement for earlier vehicles, which is what I've done - £25 including UK postage.
Click image to enlarge Click image to enlarge Thanks for looking. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 28th Nov 2017 6:47pm. Edited 1 time in total |
21st Nov 2017 2:53pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
Could I ask what colour they are please ?? Green ?
21st Nov 2017 2:55pm |
Yeah, sort of a metallic green. Darren
21st Nov 2017 4:08pm |
It's not difficult to change their colour. These started out as the same as above:
Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
21st Nov 2017 5:12pm |
Bump Darren
27th Nov 2017 9:09pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
Suitable for a td5 and any play in the hinge pins?
I did get another set to replace the ones I have now but must have been older type and when bulk head changed I was told not compatible.? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Nov 2017 8:33am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
All hinges are compatible, the only difference is the bolt head shape and thread type. If changing type you have to change the captive nuts in the bulkhead from imperial to metric thread I believe
These are Td5/puma type 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th Nov 2017 8:39am |
These are late hinges and I've fitted a comparable set to my 200tdi, so they're compatible with everything. As Grafty says, the only difference is the thread of the captive nut in the bulkhead, but that won't be a problem for a TD5.
There's no play in the pins - at least no more than typical new hinges, anyway. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
28th Nov 2017 9:15am |
