Home > Td5 > Dummy CAT
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Dummy CAT
I have tried looking but cannot see anything
Have an 04 TD5 90 with no CAT, anyone where I can get a CAT sleeve or a dummy CAT from to put on the exhaust?
Its only a visual check for the MOT but cannot be arsed refiiting every year
Many thanks all
Post #667310 27th Nov 2017 6:08pm
bankz5152
My 04 just passed full decat. My 02 90 passed everytime as well
Try Allisport
Post #667312 27th Nov 2017 6:18pm
simon67
Mine is running a OEM decat section, I need something that I can put on that looks like a CAT
Does that make sense?
Post #667313 27th Nov 2017 6:21pm
dorsetsmith
Post #667315 27th Nov 2017 6:24pm
grafty99
Same here, what we are getting at is that you may not need a dummy cat for it to pass Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #667316 27th Nov 2017 6:25pm
simon67
OK - I will shove it in with the decat from a pre 02 and see what happens
Worse case, I spend a hour putting it back and then removing it once a year
Trouble is, she runs much better without
Post #667317 27th Nov 2017 6:28pm
mk1collector
Knock all the internals out of your cat. Ray
My build thread
Post #667322 27th Nov 2017 6:52pm
simon67
I would do the knocking, but also don't want the rules to change yet again and have to buy a CAT
The exhaust is in pretty good shape otherwise I would simply change it for a large amount of folding, so bought a pre 2002 OEM exhaust
Just looking at options for getting it through the MOT, without changing every 12 months
Fingers crossed for the MOT
If anyone has any other options, apart from knock the internals or buy a decat ready made let me know
Post #667348 27th Nov 2017 7:37pm
JWL
With a Td5 it's not just a case of poking a big stick down the pipe, there's bends in the pipe plus it's a long way from the pipe joint. I had been replacing the cat for every MoT, as you say it's a visual check and I didn't want to put my MoT tester in an awkward position if the Inspector walked into his workshop when mine was in for its test. So a couple of years ago I slit the cat box open with a slitting disc and took out the internals, then welded it back up.
Post #667379 27th Nov 2017 9:02pm
bankz5152
I know what you are on about, thats why I mentioned Allisport, I believe they make a dummy CAT. What I was saying is my 04 110 just passed its MOT at a pretty by the book garage, never mentioned the lack of CAT, my 02 90 passed everytime at 3 different garages with no issues as well.
So unless you have previously taken it to your garage and its failed due to the lack of CAT then I wouldnt be too worried about it!
Post #667504 28th Nov 2017 11:36am
simon67
Thanks Bankz
Going with that option
Post #667506 28th Nov 2017 11:37am
bankz5152
Cool post back what happens. I had a poll going on Landyzone a couple years back no one (out of 40 people) reported a fail from a Decat, all years, Fenders & Discos all across the country. So I wouldnt be too worried but keep your CAT just incase for the future!
Post #667508 28th Nov 2017 11:45am
simon67
First of all Allisport don't do a deCAT sleeve, its the whole unit
So had the deCAT done yesterday by my Son and on the TD5 it is brilliant, no lag and the ride is just so much smoother
Only cost £80 from Duckworths for a pre 02 pipe
Old one in the shed just in case
Recommend, until I have the MOT Sad
Post #667714 29th Nov 2017 7:06pm
Neilios
England 1997 Defender 110 300 Tdi HCPU Keswick Green
dorsetsmith wrote:
that's the sort of CAT i like!
Post #669388 6th Dec 2017 9:52pm
Procta
It will run miles better, As CATs really do strangle diesels. My HDi really did open up massively when i removed mine, The MOT tester fitted the DEcat to it, He said it does nothing to a diesel anyway. Every since then its gone through, just throw the car in for an mot. If it fails on not having a cat, then take it else where. Some Mot testers find that the MOT rules are a little silly at times. My tester said as long as it passes the noise levels and smoke test, all will be fine. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #671259 16th Dec 2017 5:51pm
