Home > Puma (Tdci) > Puma Reversing Light Not Working!!!
Page 1 of 3 123>
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Out last nite and I realised the reversing light is not working.
Today I went to replace the bulb, but thats not it.
Perfect earth.
Only 7.8 volts on the positive terminal.
Any ideas guys?
Many thanks.
HK07 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #667031 26th Nov 2017 4:47pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Not got the diagrams with me, as I'm at work, but I'd have a look at the wiring diagram and see if there's anything else on that same circuit.
If nothing else is having issues, a complete guess would be dodgy reverse switch on the gearbox.
Post #667035 26th Nov 2017 4:55pm
HK07
Hk07
Thanks BenB8man
Yes that was my first thought, but why does it show 7.8 volts?
If the switch is knackered surely it would be dead. 2007 90 Puma - Love it - Best car I have ever owned.
Post #667036 26th Nov 2017 4:59pm
BenB8man
Your guess is probably as good as mine! Wink
If you take off your cubby and bottom plate you should be able to access it fairly easily. If you switch to ohms and click in into reverse and back you will be able to work out what the switch is doing. Might just be high resistance through the switch which drags the voltage down.
If you’re no further forward by the time I get back from work I’ll have a look through the wiring diagrams and see where it’s fed from and if anything else could affect it. That’s if no one beats me to it Smile
Post #667040 26th Nov 2017 5:06pm
HK07
Many thanks 2007 90 Puma - Love it - Best car I have ever owned.
Post #667044 26th Nov 2017 5:10pm
This. ^^^^
You might also find like I have before that an LED will work but not a standard incandescent bulb.
It will likely be the reverse switch. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #667059 26th Nov 2017 5:33pm
Martin
Site Admin
Had this on a friend's 90, new switch sorted it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #667065 26th Nov 2017 5:58pm
Roverrobbie
2007 Defender 90 Puma 2.4 HT Keswick Green
Had this problem . The switch contact had a high resistance . Replaced it from underneath using a 22 mm spanner. A bit tight for space but not too difficult.
Post #667077 26th Nov 2017 6:30pm
Bluest
Me to. Was showing voltage at the light, but not illuminating. New switch fixed it. 2007 110 TDCi Station Wagon XS
Post #667081 26th Nov 2017 6:37pm
HK07
You can do it from underneath can you?
If you do it from inside what is it; cubby box out, seats out, carpet out, then some sort of cover off to expose the gearbox?
Is that about right?
Once again - thanks for the advice.
Post #667082 26th Nov 2017 6:38pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Had to do mine recently, similar symptoms.
Apparently you can do it from underneath, I personally took the cubby box out, took the access panel out and did it from the top. Get a 22mm open ended spanner to make like easier, shorter the better. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #667086 26th Nov 2017 6:45pm
zsd-puma
Take the gear sticks out and take the gearbox tunnel cover off, that gives you the best access. It's not difficult to remove the cover. The switch on a puma is quite a way forward compared to earlier models, just forward of the gear sticks.
Might be possible from underneath, but will be exceedingly awkward i think, and burried amongst pipes and cables.
Post #667098 26th Nov 2017 7:10pm
dgardel
Italy
Re: Puma Reversing Light Not Working!!!
Perfect earth.
Any ideas guys?
Many thanks.
HK07
Same here, new switch Solved! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #667408 27th Nov 2017 9:46pm
HK07
Hk07
With my Mot looming i finally got round to buying the new switch.
Got all ready to start the job when I realised it's working again!
How can this be?
Should I replace it anyway? 2007 90 Puma - Love it - Best car I have ever owned.
Post #704515 1st May 2018 10:11am
meeerrrk
Mine was intermittent- i’d suggest replacing it anyway. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #704516 1st May 2018 10:17am
Page 1 of 3 123>
