![]() | Home > Puma (Tdci) > Strange Sucking Sound. |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Its fairly easy to check if your exhaust is leaking. A visual inspection will normally show a sooty mark where its coming through.
Although in your case if its a sucking rather than blowing sound, it would suggest the problem is intake side. Have a look under the bonnet and check your intercooler pipes etc. See if you've got a split hose. It could also be weakened intake pipework or a blockage that collapses a hose during peak power/maximum intake suction. Obviously when it collapses air will end up getting sucked in from elsewhere. |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 ![]() ![]() |
Thanks for the advice. I will get a look tomorrow.
