![]() | Home > Maintenance & Modifications > 90 50th Anniversary Brake Upgrade??? |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Dont think you will need to be specific to the 50th Anniversary model. I think Alive tuning do some fro Defenders. Im sure others will too. Current:D4 HSE
Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
don't think so! theres only 1 50th annni model. Drive slower could be an answer?! never had an issue with the brakes on my TD5 amd you V8 ain't as fast ![]() |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
Have you tried asking on www.Defender50th.co.uk ?
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I expect the brake assembly is exactly the same as the diesel models, as it is the same with the Discovery V8 and Diesel models.
![]() I cannot see land rover going to the expense of using an alternative brake setup, just for that model. ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Land rover - im almost 100% sure - didnt change the brakes they down powered the engine instead
