Home > In Car Electronics > Rear speakers (first installation) don't work
lindbergh_sosl
Italy 2011 Defender 110 Puma 2.2 CSW Fuji White
Hello everybody,
need your help, please:
I have installed in my Def 110 SW mod year 2012 (2.2 puma), an HU Alpine 196 DAB + rear speakers Alpine SPG 13 C2 (130 mm diam.) where no one was, and so have drilled rear panels and connected to speaker connectors, but no sound from them.
Connectors were plent of dust but after sprying specific cleaner spray no resolution.
The HU works well with front speakers, and so imagine connections are correct......
Any suggestion?
THX
Post #666319 22nd Nov 2017 8:47pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
You’ve probably checked this already, but is the fader setting on your Alpine radio set to front speakers only?
Post #666326 22nd Nov 2017 8:51pm
lindbergh_sosl
Yes I checked, and this is not the question.
Thanks
Post #666331 22nd Nov 2017 9:06pm
First check continuity ie check that they are connected front to rear
My guess is they are not
Post #666384 23rd Nov 2017 7:20am
lindbergh_sosl
How can check it?
Sorry but with wires and elecrticity am in trouble.... Very Happy Very Happy
Post #666462 23rd Nov 2017 4:42pm
You will need a Multimeter. Thumbs Up
Plus check connection plug behind radio, you will need to Dom this to continuity check anyway. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #666465 23rd Nov 2017 5:30pm
lindbergh_sosl
Ok this evening I'll buy a multimeter amd make the test.... Very Happy
But nobody knows if DEF models without rear speakers yet mounted have some little trick to solve as mine (disconnected cables or anithing else)?
Post #666675 24th Nov 2017 2:49pm
mk1collector
If it has the wires at the back of the vehicle, make sure the same coloured wires are in the plug at the back of the stereo. If they are at the back of the stereo and connected to the stereo wiring then as said above you'll need to check for continuity as there must be a break somewhere. Ray
My build thread
Post #666681 24th Nov 2017 3:28pm
The front wires are normally present but hidden under matting towards the front but not connected.
The other end is present at the rear speaker locations, my guess is they are not connected at the rear of your HU on the audio output plug.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #666682 24th Nov 2017 3:31pm
lindbergh_sosl
Your guess is right!! The rear speaker wires arrive until under the passenger seat and there are interrupted at the junction between the chassis and main harness; so I made extensions of the four wires until the dashboard behind the stereo facia panel...
At the edge of every wire jointed a female ISO terminal to insert into the connector C0092 at slots 1,2,7,8, but it seems cavities are not able to receive these terminals... Banging Head Banging Head Banging Head Banging Head Big Cry Big Cry Big Cry
... And now?
Post #667336 27th Nov 2017 6:12pm
PaulMc
Make sure that you have slid the Yellow terminal locking bar out of the connector housing first.
With this in place, you can't insert or release the terminals. Paul.
Post #667384 27th Nov 2017 8:27pm
lindbergh_sosl
Thx Paul, but can't understand what you are referring to, could you better explain, please?
Post #667422 27th Nov 2017 11:02pm
PaulMc
There's a Yellow terminal locking bar that slides into the side of the factory (Tyco) ISO connectors.
Shown here on a new connector, in the 'open' position -
And here, removed from the connector housing -
This Yellow locking bar needs to be in the 'open' position (or removed) before terminals can be inserted or released from the connector housing. Paul.
Post #667433 27th Nov 2017 11:39pm
lindbergh_sosl
Thanks a lot Paul, I will check tomorrow but from now am crossing the fingers... Very Happy Very Happy
Post #667456 28th Nov 2017 7:23am
lindbergh_sosl
Finally was able to connect the rear speakers, thank you again guys, without your help couldn't obtain any success.
Bow down Bow down Bow down
Post #667782 29th Nov 2017 9:09pm
