Home > Puma (Tdci) > Immobiliser light |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
The light on the left if it stays on, should mean your battery in the fob needs replacing
20th Nov 2017 4:42pm |
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 |
I am so going to try this today! I've had the same issue for months wondering what on earth was happening ......
21st Nov 2017 11:27am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
From LUCAS 10AS ALARM- System Overview:
Low battery error: This configures the alarm to notify the user via the Security LED either on the first receipt of a key code in which the low battery flag is set or to wait until it has received a number of them in succession. The exact number is determined by the value stored in the LOW BAT COUNT box. Battery Error: When set to ENABLED this configures the alarm to notify the user via the security LED that the plip has a low battery in accordance with the other settings which affect this function's operation. When set to NO the function is totally disabled |
21st Nov 2017 3:35pm |
Willbof Member Since: 07 Nov 2017 Location: Cardigan Posts: 30 |
Hmm, bit strange because it only happens after I’ve stopped, not locked it and started it up again. I would’ve thought a low battery alarm would be on all the time?
21st Nov 2017 4:21pm |
Changed the batteries in mine and it's fine now
21st Nov 2017 8:54pm |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 |
Does the motor still crank but not start if the immobilizer is on?.
22nd Nov 2017 4:22am |
90dv Member Since: 29 Jun 2011 Location: Cumbria Posts: 36 |
10AS function means it'll allow the vehicle to crank while doing security check with PCM through IPK. If the security check isn't successful (no fob detected) the vehicle will stop cranking. Usually get crank and fire but then cuts out immediately. This is done to avoid a delay in cranking while fob immobiliser code is checked.
22nd Nov 2017 9:17am |
Runs fine, can drive around no problems except a bright red light in my face
22nd Nov 2017 6:42pm |
PRENT1 Member Since: 02 Sep 2015 Location: bromley Posts: 42 |
The other night i returned to my 2.2tdi to find neither of my fobs working, on opening the car with my key no central locking. when i put the key in the ignition no turn over but triggered the alarm..
AA came no joy tried several things ECU read; fault code/s:System : Engine control - 7MF / Diesel CR/EDC ZSD 422 Status :B1206 - Crash data stored. Error Message : Malfunction Flat beded it to my local LR garge they have told me £2k to replace the alarm module(fried was the terminology) and some wiring. Any ideas in the Bromley, Kent area? |
2nd Feb 2018 10:43am |
20amp fuse under the steering column!
2nd Feb 2018 10:49am |
Top right hand side if I remember correctly
2nd Feb 2018 10:50am |
