Home > Maintenance & Modifications > Tyre Inflator
discomog
Tyre Inflator
I currently have a PCL Mk2 tyre inflator, which I confess must be 30 years old and has given good service but I have doubts over its accuracy. I could get it serviced and recalibrated but I'm not sure I want to spend money on something that is 30 years old.
Do any members have one of PCL's latest Accura Mk4 with digital display and if so can you recommend it or indeed any suitable alternative. This is for use in my garage with a compressor and therefore do not want to go down the avenue of a combined air compressor/tyre inflator.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #665706 20th Nov 2017 10:44am
My workshop inflator is a PCL but the traditional type, not the digital type, and I cannot comment on the latter.
I have however never been let down by a PCL inflator.
Post #665739 20th Nov 2017 12:45pm
zsd-puma
They pretty much come back as good as new when you get them serviced. A little scruffy looking on the outside but with mostly new guts, good for another 30 years at least. Have you checked the accuracy against a cheap digital gauge? Unless they've been abused (on a petrol station forecourt for example), they rarely give much trouble.
The digital one will need batteries replacing periodically and the LCD may become unresponsive in the cold. The batteries are bound to be flat when you need to use it in a hurry or don't have any replacements to hand. Although i suppose the backlight may be handy in poor light.
Post #665752 20th Nov 2017 2:20pm
discomog
Zsd-Ouma. There is a discrepancy with the reading. If for example I put the tyre valve connector onto a tyre it reads for example 1.5 bar, take it off and put it straight back on the same tyre is can read 1.3 bar. When using it on my trailer tyres at nominally 4.7 bar the discrepancy can be as much as 0.5 bar.
Did you have yours serviced by PCL or someone else? Defender 90XS SW
Morgan Plus 8
Post #665768 20th Nov 2017 3:31pm
